The clutch has started to slip on the tractor.:thumbdown: I dont have a manual so im struggling for info.
Dose any one know if you can adjust anything, maybe on the pedal or any where ells to ease the problem, or is it the case of new clutch. :blushing:
Any body done a clutch? any tips on whats involved, costs.
Also any info on anyone that would fit one in the central belt Scotland would be appreciated.
Cheers,
Rob
I have the 6400 manual on cd, I'll try and dig it out. I know a guy in the borders..
Cheers Tom, would appreciate that. Boarders are probably a bit far, hopefully I could get some one nearer.
Rob
Try ringing Jas P Wilsons. They should be able to tell you if you can adjust the things. I don't think you can adjust it but i'm not a 100% on that.
I've only ever broken a PTO clutch and thats because someone had adjusted it to hide another problem. I think it was about a day and a half for the change that they did in the barn. Was around 2k with parts labor and fluids.
Any good agri engineer should be able to do a clutch although i think that it may be easier in the workshop.
