Got a mcculloch hedge trimmer it takes a while to start it when you do get it going when you give it full throttle it just dies on you plus when you take top off fuel tank it's pressurised in the tank
Sounds like lack of fuel - look at the fuel filter, check the fuel line isn't split, check the carb internal gauze filter/strainer isn't blocked.
It may be worth just trying to richen up the H screw 1/4 turn before diving under the top cover!
Also worth checking the exhaust port isn't full of carbon - common issue with hedge trimmers.
