Mini digger ripper tooth
Tomf
Hi guys,
Has anyone used a ripper tooth on a mini digger for pulling out stumps/ roots
I have a 3 ton Kubota with a thumb attached and I have quite a few roots to clear. I've Been looking online at the rsl root ripper and digbits make one also.
Just wondering if they work better than a narrow bucket before I order one.
Thanks in advance, Tom
Having the blade on the rear is a real advantage I had a stump which needed taking down could not get a grinder nearing as in a ditch and had fibber optic telephone line running near to the sump I used the blade to break down the just below ground level leaving side nearest fibber line in disturbed if the desgin on the wear tip is changed it would be spot on
