i use the same bar/chain... its a joy!
once it has had a bit of use i will shave down the width of the guard teeth a bit to improve efficiency, i also find the back corner of the teeth need a bit more of a trim after a while but i think i just cant stop fiddling with the chains :)
  • Replies 24
Got the bar/chain/sprocket today was was surprised it's not a lot smaller than the standard MS150 micro chain bar for tip radius. I put it all together and did a little carving with it, using it on the side is really nice but in the cut is very slow compared to my 150 standard set up making it feel blunt.
I will stick with it, I think I had the chain a little to loose as it was kinda folding over the bar when planing on the side. Also I may be running it to slow, I keep the revs down due to a neighbor and this carving chain does not appear to like the very low revs as the standard 150 chain does.
I will stay with it, it can only be me at fault as so many proper carvers use this chain.
