Hi all
We have an old 2003 6inch timberwolf and the bottom roller bolts have sheared off. They are on the grease nipple side of the machine. I have removed the in feed Shute then undone and removed the roller pump. Can you advise me on how the remove the roller , thanks
Hi all
Hello Wrighttrees
To remove the roller from the roller box you first need to remove the spline drive by taking the 3 cap screw out of the other end of the roller.
Spline drives can be difficult to remove and you may need to involve a Timberwolf dealer to assist you with this.
Details of your nearest Timberwolf dealership can be found on our website Timberwolf UK | Introduction
Hope this helps
