Hi all. 200 was playing up few weeks ago, had a diaphragm kit and fuel pick up body. Worked great for 2 days then the next idle was all over, wouldn't pick up and lost power when cutting. Next day fine.. Happens when saw is cold and hot.
Any ideas chaps? Fuel lines?
Jon
Jon
Carb accelerator pump, leaking welch plug, stuck check valve, resin in the low speed circuit, split fuel line, dirty fuel filter, bunged up gauze filter in the carb, airleak in the crank seals/manifold/impulse line.....take your pick - all will have similar symptoms!
