Evening ,
Does any one know if the rear Hydraulics on this model can be locked into float in order to run a splitter?
I have been looking at one today and when playing with the Hydraulics lever in the cab could not work out how to lock it out?
Any help greatly recieved
Would you not need to lock it in positive flow as float is mainly used for lowering trailers and running some implements but the log splitter we have got has a lever on it with the pipe from the tractor to the log splitter is flow and the one going from the splitter back to the tractor is the return line.
Matt
