Hi all,
Saw a thread a while back about a hydraulic powered chainsaw on an Alaskan, but can't seem to find it now. There more I think about it the more sense it makes- stacks of power, no smoke, low noise, cheap running costs. I saw Rob D had put up some pics, Rob do you know what type of hydraulic saw they were using? Has anyone made one of these using a hydraulic motor and a harvester bar? I see you can get 16tooth sprockets for .404 chain, so a fairly fast hydraulic motor should be able to just about match the chain speed of a 7 tooth sprocket at 10,000rpm.
Look forward to hearing what you all think,
Rob
It was from John Lloyd Rob - can't remember which thread it was in... I will try and post the pics up. I'll try and get some details off John as well..
