Hi there.
Just wondering if you could advice me on how tight the nut holding the wheel hub on should be? should it just be as tight as it can with the wheel being able to still turn freely? then put the split pin in? seems pretty lose to me?
Advice would be great
Thanks
Stub Axles fitted with castellated nut and split pin;
when refitting these ensure the bearings are packed with bearing grease and the rear seal (where fitted) are not damaged, (replace if damaged).
Tighten the castellated nut until side play is removed and the split pin aperture is lined up with the castellation. Insert split pin and bend protruding ends in opposing orientation.
It may be worthwhile taking the machine to an Authorised Timberwolf dealer if you are unsure.
Hope this assists
