the chain brake handle is only metal pipe anyway,easy to fabricate,would not a 1 or 2 seris c/b handle fit?(plastic one)
'Fraid my Husky parts knowledge doesn't go that far! I'll do some more research though, cheers!
Also cheers Ferguson, that's what I'd thought but haven't used one. Looking at a small mill to produce featherboard for a new barn going up shortly.
hi dan
i might have a side cover with handle about i use to have a 480cd and put a new side cover on it the old cover needs a brake band so if yours still as the brake band you might be able to make a good one out of the two
i will have alook tomorrow to see if i still have it
thanks albert
Cheers Albert!
I've been away for a few days but I'll have a look tomorrow. It should do, the cover is still on and it looks like the original handle has been damaged rather than removed.
