Hi all,
I was kindly given an old 254 which needs a touch of work. Runs well but isnt oiling. Checked the worm gear which is fine so new pump time i reckon. Does anyone have one or an old duffer that they may want to donate/sell?
Cheers,
Andrew
Hi all,
Cheers,
Andrew
It will be worth pulling the pump off and making sure the thing isn't plugged. Also make sure the pick up filter and pipe is OK and the outlet hole to bar oler channel is clear - it may save you the hassle:thumbup:
Cheers for the advice. She's in bits currently so i'll whip the pump off and give it a once over then clean out the pick up. At least then i'll have explored all avenues.
I'll let you know what happens.
Cheers again,
Andrew
