I understand 1.25" is the standard band width for most of the Woodmizer/Norwood/TimberKing type bandsaw mills.
I have note a couple of manufacturers offering the option of 1.5" wide blades, on mills I am considering.
Is there any sensible merit in going wider.
Or are the wider blades more difficult to source or significently more expensive.
Or what?
"J",
I was literally coming back to amend my post to include the 2" band option (CooksSaw AC-36) having thought to double check the specs.
Yes the bigger band-wheels, were as you will recall, my prime reason for wanting the LM15 Mill from LogMaster, as I intutivetly understood the engineering benefits of the larger diameter.
I presume the wider and thicker band can also be strung a lot tighter, before risk of failure, and is also less "twisty" anyway.
Marcus
PS
Did I ever mention I was a "perfectionist" by Sociometric:lol: profiling.
This is not all good.
Particularly susceptible to "Analysis Paralysis", for a start!!
m
