Anyway, the FM starter is quite easily jammed if re-assembled wrongly, it should be the rewind spring attatched to the rope guide, then a thin metal washer, plastic washer, rotor friction arms, plastic washer, metal washer, spring, big metal washer and an e-clip, if anything is missing, it doesn't work
Sent using Arbtalk Mobile App
Hi, ok i've found out its a FM starter and all the parts are there how do i either tighten the recoil spring or make it so the cord winds in fully because at the moment it doesn't wind in all the way there's about a half inch that hangs loose
You normally wind the cord on to the pulley so that on full extension, the pulley can still be rotated that little bit further clockwise - this is to ensure the spring isn't taking the impact of the starter and if done correctly, should pull the recoil rope in. A little light lubrication helps as well.
Pull the cord out a little, grip the starter so it can't retract, push a bit of cord back into the starter area and wind the spring two turns tighter by using the cord to turn the wheel
Right ok i'll try that and see what happens.
Thanks
