Hi
My feed rollers won't go forwards, they reverse fine. They do turn forwards for maybe 1/2 second after you press the stop bar, or the stop button.
Would say to me the switch works, but the relay or something electrical is faulty? Any ideas where to look?
Thanks
Charlie.
Hi Charlie
The rollers should not change direction momentarily when you press the stop button unless the hydraulic spool valve is not stopping at the central position.
If the rollers do not go forward it could be engine RPM is not correct, one of the switches or latching relay is defective.
You could call Timberwolf's technical helpdesk on 01449 765820 for further info, make sure you have your model and serial number to hand as they will need this to give you correct info.
Hope this helps
