As already said, it is your carb that needs attention. I had an issue about a year ago. Carb kit sorted it. If you don't use that much fuel you could be wise to use aspen in your saw. It will not degrade as fast and be better for the saw. Using fresh fuel will prob not do much without the cab having some attention.
Even if he switches to aspen (highly recommended), he still needs to do/have done the work I previously mentioned
Sent using Arbtalk Mobile App
