So I've replaced the lines, you may also want to check the oil impulse, as this can stop the chain oiling, and more importantly, cause an engine seizure!
The impulse line is the little yellow pipe, near the centre of the picture
Also cleaned the carb, will order a new kit tomorrow. Carb is a hl112c
Look at the size of the pumping diaphragm!
Sent using Arbtalk Mobile App
