Serial number 7568
Hello
On the fly wheel of this machine where the bolt holes are to attach the blades the metal has worn through to the thread now. Is there replaceable anvils for this machine or does the whole fly wheel need replacing?
Thanks
Josh
Hi Josh
The rotor disc will need replacing, If your machine still has the original rotor disc fitted it will be the welded in type shaft which is no longer available.
Replacing with the later type rotor and shaft is not straight forward and best carried out by a Timberwolf dealer. Please fell free to call Timberwolf's technical support helpline if you need any further information, they can be reached on 01449 765820
