Serial number 7568
Hello,
I have a Entec 150 chipper, the rollers have stopped moving today.
When pressing the inwards or outwards roller control the top roller twitches very slightly but neither move. Do you have any idea of what this problem could be caused by?
Thank you
Josh
Hi Josh
The serial number indicates your machine is a CH30DH from 1997.
Originally your feed rollers would have been controlled by the safety bar which would put the problem cause down to hydraulic issues, but I suspect the machine has probably been retro upgraded at some point since manufacture when safety standards changed. Give Timberwolf's technical support helpline a call on 01449 765820 they should be able to help.:thumbup1:
