Eye burning bit
thewoodwizard
This was made out of an old round head allen bolt, from an old swing seat. The head of the bolt is 16mm wide, and the drill bit was 13mm. Drill out the head of the allen bolt to the required depth. This could be done to a normal bolt but you would need to round of the outside first, then centre punch for the drill. This works on friction to burn the eye, I use a household drill.
I've attached some pictures of the finish work.
Regards
Ray
