Evening guys,
Last time i checked the boards i think was a year or more ago. Since then i've been working for G&T and loving it. Bought my first saw today, the 550 xpg. Used to Sthil but heard good reviews and liked the one i used on my felling course.
Just fitted the bar, seated the chain tensioner, tightened the nuts and the engaged the chain brake and now it wont come off.
Did i do something wrong?
thanks for reading
The tensioner has a conical pin. If you adjust the chain tension and then tighten the nuts whilst they were still fairly loose, it forces the fatter part of the pin in more which tightens the chain more.
So you need to only have the bar nuts just loose enough to be able to move the bar enough to adjust it.
ok, seems to be working much better now. the chain brake seems kinda sensitive. It's jumping back to engage now. Is there something not right again?
Thanks Dan.
The bar nuts are really good, like the hanging jobbies
Wow, i got it. likey lots, you really jam your hand in there behind the brake. And i have to engage it with my whole hand, not just above the lever
sweet
