Has anyone here fabricated their own shoulder straps for their harness or know of any that can be modified to fit a petzl sequoia (non srt) or skylotec? I see some other manufactures do shoulder strap kits but nothing specifically for either of my harnesses. Only needs to serve as support when carying larger saws on harness. Any suggestions appreciated,thanks.
That's the sort of thing I'm after.I seem to recall a post ages ago where somone made up some straps to fit a tree motion for SRT but can't find it.
Girth a sling round the back pad, then do the same around the waist belt, simple. You'd probably want some sort of padding in there though. I use a petzl top on a sequoia srt for big saw use, makes life so much more comfortable
Cheers for the suggestions everyone,I've tried a few thing and come up with this so far. Needs a little fine tuning,will probably replace the carabiner with a length of cord to make it adjustable and replace the slings with some wider ones for better comfort. Any criticisms welcomed. ImageUploadedByTapatalk1383848020.778083.jpg.b10ecbb21ca0cd5c63464f29be23e090.jpgu2u5aset.jpg
Brush for demonstration purposes only... :thumbup:
