Hi all,
I have just obtained a TK75-2 from LED Torches, Head Torches, Flashlights & Torch Accessories. From EagleTac, ThruNite, Jetbeam & many more... who were very helpful along with four 3400 Ma/Hr 18650 LiOn batteries & Nitecore i4 charger which will also charge other types and sizes of battery.
Its very well engineered so not cheap but the light it gives out is nothing short of astonishing, unbelievable brightness illuminating objects hundreds of meters away like daylight.
An additional switch cycles through 4 settings, so battery life is extended at lower light settings, the lowest is about the same as a standard torch, the next is bright after that its like car headlamps on full & max like a lighthouse on steroids.
OK, this may be OTT but its very bright & perfect for lamping or any other application that demands lots of light.
N
Thanks for postin this. I need a new head torch.
Sent with my iPhone from me, to you!
Hi,
Excellent place to get one from, they were very helpful on the phone, assisting selection of batteries & charger - which is capable of charging a wide range of LiOn & NiMH cells.
Recommended
N
