Big blade is for the FS550 but ignore your dealer if he tells you it won't work. FS450 is more than man enough, I ran it on an FS400 with no issues at all. Momentum is all you need, then just tickle the throttle.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
