Dolmar/Tillotson injection carburettor help please?
Adamam
Hello!
I have a Makita DCS6000i (Domar PS6000i), and need a tiny bit of help with the choke valve.
Does this valve just have two positions, or does it unscrew all the way out?
I ask because at the moment it runs with the switch in the choke position, and cuts out in the 'start' position (and won't start).
I wonder if at some point the valve has been turned 180 degrees which would cause this to happen, but I don't want to ruin the carb if this isn't the case (by turning it 180 degrees back).
It'd be easy to do this (by accident or design)...
If I keep turning the valve clockwise, should it eventually fully seat, or does it turn indefinitely?
:confused1:
Thanks so much for that!
Those threads were very helpful. I'll fiddle more today, and if I can't get anywhere then I'll see if that chap can offer any ideas...
Thanks again.
TCD, do you have a price in mind? Maybe you could PM me if you do?
Cheers!
