Do you have a picture?
Edit: 16 strand splice if its the Patriot climbing line.
I can splice it for you, I am based SW.
PM if you want.
Edited by High Scale
I think it's a Yale rope.
I'm happy to do it, just need the advice on which technique to use. Recently made a tidy job of Marlow Gecko and apparently this should be easier. The blue core is 8 straight double strands with a thin plastic tracer tape thingy.
Yes I think your right that its Yale.
It is a 16strand rope so do a 16 strand splice.
Cover strand removal is slightly different from the Marlow I think.
Was that scientifically tested to destruction or a failed attempt to lift a heavy thing out on site ?
Are you getting samples tested to be able to gain certification for the splices you produce ?
I had a few splices broken double braid and 16 strand after a very kind offer from somebody in the industry.
I broke them for peace of mind really but CE certification for hand splicing is obtainable.
I have never broken a splice in day to day tree work, although I'm sure I could if I tried:)
