Timberwolf 190 Springs
woodyjjw
Hi Woodyjjw
Generally the springs do not require changing, the most important requirement is to keep the top roller slide plates well greased as per the machine manual service instructions, this will help stop any "hang up" of the top roller.
Springs do weaken slightly during use, this is normal for any spring, but should not affect the pulling power of the rollers if the greasing regime is observed every 50 hours.
If you do not have a manual for your machine, a copy can be downloaded from the web site Timberwolf UK | Introduction.
If greasing does not resolve the problem Timberwolf operates a Technical Support helpline which may be able to assist further on 014490765820 :thumbup1:
