Eco arborist
Daniel Jiggins
Our local hire centre bought one about 18 months ago and we take it out pretty regularily. It's a cracking wee machine and does all asked of it. The only problem we ever encountered with it was an overheating issue during the really hot spell in July when the radiator screen clogged up wiith dry material causing things to cook up a bit. Problem easily solved by checking and clearing the screen more regularily in those hot dry conditions (which we probably should have been doing anyway but we're just not used to more than 2 hot dry days back to back in NW Ireland!)
Best of luck with the eco-arborist. Don't think you'll be disappointed
I've installed some mesh inside the outer casing (where they have cut-outs for the GM logo) where the air is drawn in. We can see when these are getting clogged and clean the crud off before there's an issue.
The inner screen only needs a brush down on the weekly check. Never clogged and overheated.:thumbup:
