So.004 cold and .006 hot on intake and
.006 cold and .006 on exhaust.
Not too hard to find out I guess. :thumbup1:
Cheers. Just sent those on to the man who is doing the work. We are also having another oil change and replacement gasket as the old on was leaking a bit.
Just heard from the man doing the work, it appears when the gasket was replaced a small amount of gasket sealant got into the rocker and was holding the valves open but it looks like a fair bit of damage has been done to the valves seals and carb due to the ignition and blow back through the valves. It is repairable but its only a temp fix until it happens again.
