I would check the size of thread as they can be different. I'm having the same problem trying to find an 8mm bump head without paying nearly £50
I use these heads on my echo strimmers they use a 8mm LHT good heads too.
the only problem is, im unsure what size thread it is
Ok. You need to measure it.
A simple way is to find a nut that fits. Then it wail say on the nut what size it is. There are a few sizes out there so depends on what one you have, as to what adaptor you will need.
