If you use the Tyvec you will also need to use a sealing tape on each edge.
Just one more idea for you. I know I said the combined roofing sheets with insulation bonded to them are expensive but you can fix standard insulation over the rafters before fixing down the sheets. For cheapish insulation these guys are good value. Insulation Boards
