i need a new mower deck, as mine has rusted out, but the honda engine has not missed a beat, (only change oil, clean filter)
when can i get on?
it is only my small mower 450mm width for rough ground, will any make deck of that size do me?
You will have to get the exact deck shell for your mower if you want your handles, wheels, axles etc to fit.
You will need to post your make, model, type and serial number of your mower.
as long as the shaft and pully assembley will fit through the deck you buy you can re drill the holes to bolt the engine onto the new deck. I have a number of modified mowers as various parts have failed over the years but do try to get a similar deck
Mower engines all use the same 'footprint'. In other words, they all interchange and are all held down with three bolts.
Engines do however have different shaft diameters and lengths, so the blade may not be at the correct height.
A few millimetres difference in height can sometimes effect airflow to the point where the collection is compromised.
If swapping decks then always use the blade boss and blade which belongs with the deck, as long as the right height can be achieved.
Any modified mower will no longer conform to its CE marking. If a modification is made which causes an accident then your insurance could be void.
