The network provider for your area Scottish power round my way
Your network provider will do the tree work for you
It's not your responsibility
they already have and completely disfigured the deodar, in fairness I suppose they only cut it back to clear the lines but its a bit rough, so my customer wants it shaping and dead wooding etc. So it needs turning off before I do any work to it.
Edited by Paulc
If they have cut it to the correct distance away spec there should be no need to turn the power of to do any more work (this is only a brief explanation you should really know about vicinity zones and live zones )
If you are cutting far enough away and not going to get a shock or damage the line there is no problem
They will not drop the line or shut it down because you are scared of an unknown quantity
If it has been cut on the correct spec then there should be zero risk of a problem occurring if you are cutting away from or below the line
Edited by DM TREES
Ring the network operator and request a 3rd party shutdown - they'll want a method statement from you and proof of qualifications/insurance and will then arrange a date to turn the power off to allow you to carry out the works. I would strongly recommend you not doing the work live from your description - other than the very real risk of you getting killed, if you damage the electrical apparatus you will probably be in for a massive bill, and your insurance company are unlikely to cough up unless you have powerline clearance cover (I'm assuming you don't, hence the question).
Thank you !
Read more
