husky 45 not idling
Breezeblock
i did a comparison test on the gauge and the gauge is ok so theres nowt wrong with the piston and barrel so i stripped off the carb and the rubbers a bit worn so i decided to try pressure testing it with 5 psi pressure found the crank seals leaking when i sprayed soapy water there was hardened debris packed around the back off the clutch so new seals required
Well done, at least you know what the problem is now:thumbup:
