Stihl FS400 Clutch Problem
Grinzola
In Order to fit the new Clutch i need to remove the bottom piece that the 2 Bolts fit into
it is held on by a central bolt
( clockwise or anti to remove )
It sounds like the bottom bit you refer to is the clutch carrier. Your new clutch already has one with it.
The central 'bolt' is in fact a hex head cast into the carrier, so its no good trying to hold the carrier and turn the nut, they are all the same thing.
So you need to use a piston stop of some sort, even if only a bit of starter cord. to stop the engine turning, then using a socket on the hex undo it in standard anti-clockwise direction.
Hope this helps.
Doing gardenkits idea is best. Use a piston stop or pull cord in the cylinder will stop engine moving. With the cord ensure piston is up near the top or you risk trapping cord in rings.
Then undo the centre bolt.
