I have my strop on the left so the big hole is fine for me, even with the spool thingy centrally on the back of my belt. The only thing I find personally is that now I don't realy use the leaver on the cinch, I just twist the whole thing round for slack. I did try using the cinch up side down but it was just a bit gay.
I don't use the lever at all, just rotate the cinch, no probs even with gloves on. Only thing I'll do is out a silicon keeper on the biner to help keep the cinch orientated when the lanyard slackens.
Cheers,
Tony
Keeping the cinch oriented on the biner when slack is a good idea. Got a big leylandii job coming up in a couple of months. It might be good for that as I wouldn't have to keep dragging a strop around. Plus the fact that it's quite long so can have a couple of wraps on a branch for work position. Just got a ISC triple action snap today which is pretty easy to use. The whole thing seems to make a neat system. I'm putting a bit of red tape near the end of the line so I can stop taking out rope before it's all payed out.
Great minds bro, I placed some red whipping and lock stitched it 2ft from the end so it shows past the cinch.
Without the keeper on the cinch biner its a bit floppy and if you not careful it will side load giving a disconcerting flick as it orientates when loaded.
Cheers,
Tony
Every time I pull all the rope out the mechanism won't recoil until I dismantle the case so I'll be marking the rope later too.
[/b]
Al, has your Sidewinder always done this or has this started after you rerouted where the line comes out of the housing? The reason I ask is that I yank mine until it stops all the time and it has always been able to recoil without much fuss.
David
David
Not sure but I guess it's a good question although I don't know why it would make a difference.
Any thoughts.
Sent with my iPhone from me, to you!
I think it might be that the locking ratchet is in a locked location at the same point as your rope runs out and in the normal rope routing the spring has some movement left so a tug will allow it to rewind.
Daid
