im in the midst of building a sprinter dropside with an 025 hiab, the crane has no support legs, has anyone else built or used anything similar? my two options are build hydraulic support legs or fabricate some outriggers using heavy duty 'wind down' prop stands, the ones i have seen only have a swl of 500kg, the crane is capable of picking up 1000kg @ 1 metre reach.... although the crane is unlikely to be used at it's limit im unsure if the prop stands will be strong enough? any ideas welcome!!!
