Big Shot set up.
Old Mill Tree Care
  • Replies 45
I completely understand that, I'm trying to compile a list of bits needed to make one. I was a little confused when it was said a slingshot would not do not. So I presumed there was an alternative device you guys were using at the end of the pole instead. :-)
Got you.
The simplest and cheapest kit I've seen is the roof rack strap and Archery trigger.
The trigger is essential if you want to maximise accuracy, IMO.
What's the point in having a RopeKnight then being let down by another components. It's like putting remould tyres on a Ferrari.
Sent with my iPhone from me, to you!
Got you.
This is the one I set up with an archery trigger and tie down strap for a total cost of 30.00 dollars.
Shotgun type stance.
[ame=http://www.youtube.com/watch?v=GUdHFr9ijr0]Big Shot launcher for tree access using 2:1 mechanical advantage with capture. Under $30.00 - YouTube[/ame]
Setup overview
[ame=http://www.youtube.com/watch?v=7vg5zjA9Jts]Big Shot with inexpensive tie down strap for 2:1 mechanical advantage and capture. - YouTube[/ame]
I've been using this way for about 8 months and like it.
  • 3 weeks later...
This is what has worked for me for a few yrs.
simple i girth hitched some old webbing to the original finger pull and then added the ball made of tape and knotted webbing. I find the ball can be gripped easily by the hand and allows one to focus more intently on the shot.
Also I wire stitched in a bit of rubber to grip a slippery when wet or icy RK.
I believe the rubber grips and with its maleable and semi-rigid nature is better at propelling the weight than the bit that bit of vinyl
Highly recommend these mods for those who like me are looking for improvements.
Cheers
WARNING Caution! Keep the tail length to the ball as short as possible to avoid it catching the tailing throwline and always double check your line will pay out freely and the line bag/bucket or Sidewinder is well in front of the shot.
As well always uninstall the FASTattach/LONGgun when firing the BIGSHOT
Cheers
