1080p and wide . My editing's not that good it jumps a bit between clips and it doesn't seem as good quality as it does on my mac. More playing I think!
Hero 3 black. Got this one because it comes with the remote. Great bit of kit. Going diving in may going to try it under water. Apparently it can go down to sixty meters. Not the remote though
Good work. I find when I'm felling a straight stick, cutting a bigger face, as in 50%, will put lean to the advantage, requiring less pull and less effort. It's called sawing advantage to the lean, it's on beraneks DVD, series 3. Really worth the money that DVD series!
Peace
Why did you cut it so high?
Sent using Arbtalk Mobile App
It was only going for fire wood and there had been a seat made around the base with lots of ironmongery in the wood. Didn't want to hit anything with the saw so early in the day when I had to ring it all up.
Peace
Didn't really use the rope it was just there incase needed :thumbup:
