Heat pumps work best on SW -S facing walls, though can gather heat from other placements too. At their best, they can be a boon. At their worst, they can eat electricity. It is also important not to allow them to be obscured by overgrowth or allow things to be leaned against them. Vents must be kept clean and clear of dust, snow & wind blown debris for optimum efficiency.
A British winter may cost you dearly. Damp air can accumulate water around the pump’s heat exchanger and this can freeze. This causes the heat pump to go into a defrost cycle, where the machine stops heating the house and uses electricity to defrost the exchanger.
They can be noisy in use. Stated effectiveness and carbon savings quoted by companies, are usually based on mid terrace housing. Where there are only two exposed walls. Stats for detached housing are much harder to come by.
Edited by TGB
