The black plug suggests that the saw is running rich - lean it up on the H screw - it should be around 1 turn out - if it is this then check the airfilter is clean and if it is, lean it down 1/6th turn and try it again.
The coil may be on the way out but worth resetting the coil to flywheel gap by using a thin business card between the flywheel and coil and loosening the bolts and allowing the coil to stick to the magnet and doing them back up.
Try that for starters:thumbup:
Cheers Spud will do :thumbup1:
