066 problem
wisewood
Hi peeps,
broke the chain break handguard the other day and while I'm waiting for the replacement to arrive I thought I'd investigate the problem.
My first question is, how do I remove the metal oiler plate under the bar studs?
I can't see any obvious fixings and I can't remove the internal plate surrounding the clutch without taking it off.
What am I missing here guys?:confused1:
Also the brake band is on, I assume I can release it once I have the mechanism exposed.
Cheers,
Si
The oiler plate should just have a small slot screw holding in on. If the clutch surround wont come off it may of got hot and melted a little around the drum, a good pull with pliers should do it. Ensure all the torx screws are out, I think there's four on that saw. If none of that works, drum off I'm afraid.
Cheers Lee,
sussed it:001_smile:
The oiler plate was one of those snap on/off types:001_rolleyes: was just going at it too tentatively.
Clutch surround came off easy, released the spring and worked out the mechanics of the busted handle in readiness of its replacement:thumbup:
