hi, first post on this forum, but i wanted to know if any of you guys sell softwood (transit sized) loads of split logs and if so how much do you put them out at? ive got loads of conifer in the yard and just wondering if its worth logging up? cheers
Hi and welome to the forum.
Prices for logs do vary across the country as does quality and moisture content.
I would suggest the best way forward is to ring your local log boys and see what they are charging and for what sort of volume. Also ask are the logs sawn to the same length, if so how long, what the moisture content is, and what is the volume they are selling in, ie builders bag ( .5 cube usually), tipped load ( if so measurements of body), 1 cube bag, etc.
Last winter and early this winter I sold soft logs very dry at £80 a cube + 5% VAT.
A
