Where the heck does the impulse line plug into the carb???
TimberCutterDartmoor
Ok. Bear with me for the description. If it makes no sense then message me and I can send you a pretty picture of it. :lol:
Ok so it goes into the crank case under the carb boot. It then feeds up and under the boot. The white plastic that the boot goes to and where the carb sits there should be a small bit that the hose goes onto.
So follow the carb boot rubber and you will see it there. Between the engine and big bit of plastic where the carb sits into.
Like I said I can give ou a nice picture to help.
