curf cuts good for stopping sap wood tear out or wood pull out from buttrests. well worth it in a tree depening on what your cuting and size and wait of bow or section.
will letter box a felling cut when felling a pole, keeps control but reduce pull needed, as two 2" thick hinges is always better than a long thin hinge.
im talking about heavish stems that have been stripped. cutting the middle of the hinge out instead of making the hinge really thin.
Center punching hinge through face (or same missing in rot) is supposed to take out the stiffer area/ leave the younger/springier outside of hinge to flex. This outside area will then be thicker too.
Because the tree will still weigh same and be at same angle; therefore will start falling at the same hinge strength. Less noticeable an effect on tapered agaisnt side lean
This thicker hinge will also have more side to side control/have more power at the leveraged outer reaches.
Soren Ericson(sp?) and others have also used this technique for preserving more wood/less splintering at the fat/money end of the felled timber.
Kerfing across full length is snap cut; across full facing is similair/ both giving early close. Also risking Barberchair in full length/weight loads.
Kerfing 1 side of face, offers the other side still open as relief, and thus far less risk. Don on the control side/away from side lean; gives nominal effect; as the weight isn't slamming that side close for the responding effect. Done on lean (or down side in horizontal limb in climbing); gives harder close on the lean side. this gives a responding push over(or up). Seeing as the control side is still open; it is pulling at the same time. Between the 2 we have a push on one oend of the lever/hinge; and a pull on the opposite end/in opposite direction; for more of a tourqued adjustmeant i think. More of what Dent's hinging bible refers to as a swing dutchman i believe.
This is the outer edge/ tricky stuff; especially in full size felling. i prefer it in rigging and limbing. These trix can also be used in bucking quiet well. As in:
