Thanks guys,
I'll probably have a go at the Silverstreak and knot it in that case - i'm watching the pennies and the OP eye to eye is £33 :scared1:
arborist | eBay
The link above (if I've linked correctly) is less than £33.
Might help, might not.
Do you climb on a ropeguide or cambium saver stig? I would personally get something heat resistant if you are not just using a natural crotch. Ive ruined silverstreak in one climb before..
VT on pulley saver, point noted.
arborist | eBay
Yes, most definately if you scroll down to this one Ocean polyester 8mm 80cm eye2eye Prussic for Tree Surgery Arborist Climbing | eBay
Many thanks guys, looks like OP then.
OP, AP or Beeline. Beeline is a good combination of cheap and long lasting. I personally think AP is the best, I dont get on with OP. Running it on a ropeguide or cambium saver I don't think it lasts long enough... The 8mm beeline seems to last longer than the 10mm beeline too. I think they have different ratios of heat resistant to non heat resistant fibres in the cover.
second that.... my o p is not holding up to well with my rope guide
