Depends on what has gone wrong? Is yours a v twin? If its seized up them depending how bad it is it may only need a new set of piston rings and a the barrel honing or it may new pots, pistons and rings. You should try bondy who used to work at Haytons mate.
Hi Ben,
your could fit a 25 hp engine but it would stress the rest of the machine, after all that machine is at least 20 years old. Might be better to rebuild the 20hp. Ill private message you a guys number to call for information on Kohler engines.
Failing that if you think you could be looking for a new one.. well.. I could know a man :thumbup:
