You can use anything that works. Bear in mind that a 1600kg load means failure will be a bit dramatic. Along with shear pins inside the mechanism, the handle (proper one) is designed to fail before the winch/cable and rated shackles etc. Might be worth considering?
On the T516 the spare shear pins are stored in the rope release lever (not the handle). A genuine handle has some advantages (light, telescopic, fits well, and locks on) but isn't essential. Imho it's worth the money, but a plain tube can be used. The load is held btw if the shear pins fail.
