Efficiency of stove vs. fuel load
Stereo
Anyone got any ideas on this? I have a Villager A Flat which is a big old stove. If I fill the firebox we seem to get a lot more heat than if there is a smaller fire in the middle. I'm thinking that it's too big for the room now we have the Esse at the other end.
The question is, do you get more heat from a given charge of logs if the stove fits tightly around it than if it's a big old stove only half loaded?
As I understand it what happens is if you get the the fire hot enough you get a secondary burn of the flammable gases making the stove more efficient. We have the same problem with our unlined large cast iron stove but I think we have improved it's use when having a small burn by lining it with insulated fire board. This helps the firebox get hot with a smaller burn. Hopefully someone like Alycidon will know the answer for sure.
Edited by Woodworks
