See attached pic of chain on it's second day of use.
I will admit that this was originally a bumper tie strap chain, but as the supplier had already buggered up the order by sending 1.3mm, I couldn't be arsed to send them back again, so ground off the bumper tie strap top bit. However, the setup left behind is simply a normal chain, with normal depth guages, so the only explanation I can see is poor quality. This is the second chain this has happened to. The cutters bend, then eventually snap off, and the chain just runs rougher and rougher untill you have to give up with it.
Stihl chains in 1.1 run faultlessley without a problem, cut like a knife and generally give no hasle at all, even on an MS230.
Won't be buying Oregon chains for the small saws again :thumbdown:
