Yes it should, very slightly. Whereas with a sprocket nose you tweak it up until the chain is stiff and then slacken off just enough that the chain pulls round freely, with a hard nose you tweak it up just enough that the chain is fully seated in the bar rails. It's particularly hard to get right on a long bar, or if the sprocket is a little worn.
Alec
